Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base What are the environmental operating conditions for the AC10?
  • AC/DC Industrial Drives-
    • AC10-
      • AC10 Heat Dissipation
    • AC15/AC20
    • DESAT (OVER I) Fault
The maximum operating altitude for an AC10 is 3000m (9750 ft.). The maximum ambient temperature is 50C.
Note: The drive has to be derated linearly 1% per 100 meters above 1000m to a MAXIMUM of 20% at 3000m (9750 ft.).
AC10 (IP20):
  • Right Click -> "Open Image in New Tab" if you have difficulty reading this here:
IMAGE BROKEN -- DCLIFFE
AC10 (IP66):
15NOV2016 LS
  • environmental
  • ratings
  • conditions
  • Environment
  • operating
  • AC10
  • maximum
  • temperatures
