Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base What are the basic wiring connections of the AC10?
  • AC/DC Industrial Drives-
    • AC10-
      • AC10 Heat Dissipation
    • AC15/AC20+
    • DESAT (OVER I) Fault
AC10 IP20 Basic Connections:
IMAGE BROKEN -- DCLIFFE
AC10 IP66 Basic Connections:
DEFAULT values:
  • Relay output is Inverter fault
  • DO1 is Running
  • AO1 is Running Frequency
  • DI1 is JOG Forward
  • DI2 is External Coast Stop Input
  • DI3 is FWD
  • DI4 is REV
  • DI5 is Reset
  • DI6 is Coast Stop
View a tutorial video here: https://youtu.be/0Sf-0Ii_Mtg
For a complete quick-start guide and installation manual see the Product Support tab on the AC10 product page: AC10 Series
15NOV2016 LS
  • quickstart
  • connections
  • AC10
  • basic
  • wiring
  • inputs
