Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base What is the current overload rating for the AC10 drive?
  • AC/DC Industrial Drives-
    • AC10-
      • AC10 Heat Dissipation
    • AC15/AC20+
    • DESAT (OVER I) Fault
The AC10 has an overload rating of 150% for 60 seconds.
For a great deal more information please follow this QuickLink to the AC10 on Parker.com for the Manual and additional product support.
16NOV2016 LS
  • rating
  • AC10
  • Current
  • overload
