Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base What default configurations are available for the AC10?
  • AC/DC Industrial Drives-
    • AC10-
      • AC10 Heat Dissipation
    • AC15/AC20
    • DESAT (OVER I) Fault
For both the IP20 and IP66 versions, one of five default configurations may be selected from the keypad (F228)
  1. Application 0 NONE.
  2. Application 1 is for the basic speed control.
  3. Application 2 is for Auto/Manual control.
  4. Application 3 is for preset speed control.
  5. Application 4 mimics MOP (Motor Operated Potentiometer) control.
  6. Application 5 is for PID control.
The Default Applications are documented in Section 13 of the AC10 manual.
  • Both the manual and quickstart guide can be found on the AC10 Product Page under the "Product Support" tab.
16NOV2016 LS
  • quickstart
  • startup
  • manual
  • F228
  • AC10
  • default
  • applications
  • configuration
