Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base How do I know what firmware revision my AC10 is?
  • AC/DC Industrial Drives-
    • AC10-
      • AC10 Heat Dissipation
    • AC15/AC20
    • DESAT (OVER I) Fault
The firmware revision is based on the inverter model.  It can be read at parameter F105.
You can not flash the firmware on your AC10 to a modern revision. The major and minor revisions of firmware are hardware dependent.
  • AC10 Frames 1-5 firmware: 2.x
  • AC10 Frames 6-12 firmware: 3.x
  • AC10 IP66 All Frames firmware: 4.x
16NOV2016 LS
15OCT19 JD
  • find
  • firmware
  • know
  • AC10
  • f105
  • check
