Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base In what type of package is the AC10 available?
  • AC/DC Industrial Drives-
    • AC10-
      • AC10 Heat Dissipation
    • AC15/AC20
    • DESAT (OVER I) Fault
The AC10 is available in two form factors.
  • IP20 enclosure up to 250 HP (180kW).
  • IP66 enclosure up to 125 HP (90kW).
For more information, consult the respective manual on the product page for the AC10 on Parker.com - Manual, QuickStarts, Product Support, etc
17NOV2016 LS
  • factor
  • IP66
  • form
  • package
  • AC10
  • IP20
