Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base AC10: Is the keypad detachable during operation?
  • AC/DC Industrial Drives-
    • AC10-
      • AC10 Heat Dissipation
    • AC15/AC20
    • DESAT (OVER I) Fault
The AC10 keypad is not detachable. It is built directly into the housing on both the IP20 and IP66 variants.
The AC10 does have an option available for a remote keypad however: Remote keypad part number: 1001-00-00 --- Extension cable 1001-01-00
17NOV2016 LS
11SEP19 JD polish
  • AC10
  • operation
  • keypad
  • Remote
