Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base What are the minimum and maximum 3-phase input voltage ratings for the AC10?
  • AC/DC Industrial Drives-
    • AC10-
      • AC10 Heat Dissipation
    • AC15/AC20
    • DESAT (OVER I) Fault
The AC10 input voltage ratings are as follows:
  1. 1-phase 220-240VAC (±15%)
  2. 3-phase 220-240VAC (±15%)
  3. 3-phase 380-460VAC (+10%, -15%)
For more information consult the manual for the AC10 on Parker.com found under the "Product Support" tab.
17NOV2016 LS
  • voltage
  • input
  • ratings
  • minimum
  • AC10
  • maximum
