Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base IPA Software - Example - Excel Spreadsheet to Upload/Download Arrays
    • IPA Drive/Controller-
      • IPA Hardware - DC Power
This Excel workbook uses the ComACRserver and macros for uploading and downloading arrays to ACR9000/ACR7000 and IPA controllers.
