Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base How do I reset the master password in an AC10?
  • AC/DC Industrial Drives-
    • AC10-
      • AC10 Heat Dissipation
    • AC15/AC20
    • DESAT (OVER I) Fault
  1. Navigate to F101 on the keypad.
    1. Press [M] to display F100.
    2. Press [O] to illuminate DGT.
    3. Press [UP] to navigate to F101.
    4. Press [E] to enter parameter.
  2. Set F101 to 2015 for Master password reset.
    1. Press [O] to toggle between digits.
    2. Set value to 2015.
    3. Press [E] to enter/escape back to last level.
    4. Press [M] to back out to top menu.
    5. The password is now temporarily overridden until power is cycled. Then it is back
  3. To permanently reset the password, follow these instructions:
    1. Set F107 to 0.
    2. Set F108 to 1.
    3. Set F108 to 0
    4. Now there is no password in the drive.
11JUNE2018 LS
  • reset
  • AC10
  • Password
  • remove
  • master
