Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base How do I connect to an AC10 using a generic RS485 device, and PDB?
  • AC/DC Industrial Drives-
    • AC10-
      • AC10 Heat Dissipation
    • AC15/AC20
    • DESAT (OVER I) Fault
PDB IS NO LONGER SUPPORTED TO CONNECT TO THE AC10. IT WILL NOT WORK WITH MODERN FIRMWARE.
PLEASE UTILIZE DSELite FOR NEW APPLICATIONS.
UTILIZE THIS FAQ TO CONNECT WITH A GENERIC RS485 DEVICE VIA DSELite FAQ: RS485 with DSELite
UTILIZE THIS FAQ TO CONNECT WITH THE 1002-00 MODULE VIA DSELITE FAQ:1002-00 with DSELite
Equipment Needed
AC10 drive, RS232 to RS485 converter, PDB.
IMAGE BROKEN -- DCLIFFEIMAGE BROKEN -- DCLIFFE
Procedure
  1. Connect RS485 converter.
    NOTE: The 120 Ohm resistor must be removed to work with PDB but must be in to work with TS8000 (HMI) communications.
  2. Set up the computer's COM port.
  • Set PDB protocol.
  • Set AC10 protocol.
    Parameter Description Setting Range Default
    F900 Communication Address 0: Broadcast Address
    1-255: Single Inverter Address
    1
    F901 Communication Mode 1: ASCII
    2: RTU
    2
    F902 *Stop Bits 0: None
    1: 1 Stop Bit
    2: 2 Stop Bits
    2
    F903 Parity Check 0: Invalid
    1: Odd
    2: Even
    1
    F904 Baud Rate (bps)
    9600 is recommended
    0: 1200
    1: 2400
    2: 4800
    3: 9600
    4: 19200
    5: 38400
    6: 57600
    3
    F905 Communication Time Out 0-3000 0
    *In the IP66 version, F902 is RESERVED
  • AC10 Communication Settings
    Mode = RTU
    ASCII Mode
    Byte Function
    1 Start Bit (Low Level)
    7 Data Bit
    0/1 Parity Check Bit (None for this bit in case of no checking. Otherwise 1 bit)
    1/2 Stop Bit (1 bit in case of checking, otherwise 2 bits)
    RTU Mode
    Byte Function
    8 Data Bit
    Read Parameters, Write Commands, COM Parameters -- See Section 12 in AC10 Manual
PDB Program
Network Connection (2-wire)
3JAN2017 LS
