Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base What safety standards does the AC10 meet?
  • AC/DC Industrial Drives-
    • AC10-
      • AC10 Heat Dissipation
    • AC15/AC20
    • DESAT (OVER I) Fault
  1. AC10 (IP20)
    1. Meets the UL, and c-UL standards
      UL standard UL508C, File No. E142140
  2. AC10 (IP66)
    1. Meets UL listing ONLY THROUGH FRAME 3
    2. Meets the CE standards
      • Meets the requirements of IP66 As defined by EN60529
  3. The AC10 does not have any STO features nor associated ratings such as SIL3
    1. It can be configured with a "FAST STOP" circuit to stop the drive in the event a fast stop is needed during normal operation. Consult the FAQ in the sidebar "How do I Implement a Fast Stop circuit on the AC10?" This 'fast stop' does not adhere to various standards. It is simply an added functionality.
3JAN2017 LS
12SEP19 JD
  • IP66
  • standards
  • AC10
  • CE
  • c-UL
  • UL
  • IP20
