Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base How do I implement a Fast Stop circuit on the AC10?
  • AC/DC Industrial Drives-
    • AC10-
      • AC10 Heat Dissipation
    • AC15/AC20
    • DESAT (OVER I) Fault
The AC10 does not have a dedicated Safe Torque Off circuit (STO) implemented. It does have a "coast stop" functionality that can be configured.
It can also still be setup to utilize a configurable 'Fast Stop" circuit in the event the drive needs to be decelerated quickly. This FAQ covers that setup.
Required:
  • DSELite version 3.07 or greater:
  • One of the following AC10 drives:
    • AC10 IP20 drive, Frame 1 – 5, with firmware version 2.31 or greater.
    • AC10 IP20 drive, Frame 6 -12, with firmware version 3.31 or greater.
    • AC10 IP66 drive, with firmware version 4.31 or greater.
Procedure:
  1. Using DSELite configure the drive per the attached configuration example located below. Make sure to select the proper template for the AC10 frame and firmware you have.
    1. Fast Stop Example Configuration
    2. In this configuration to do a normal stop of the drive remove Digital Input DI1. To do a Fast Stop remove terminal Digital Input DI2.
  2. The connection line from the Sequencing Logic block /Running parameter, is a Feedback link. Right mouse click on the line and select "Feedback". See the picture in the appnote.
  3. Value Func 2 / Input A sets Normal decal time. Input B sets the Fast Stop time. When setting these times, there is a decimal shift, thus 0.1 = 1 seconds, 0.5 = 5 seconds.
6SEP19 JD
  • safe
  • E stop
  • fast
  • off
  • emergency
  • STOP
  • AC10
