Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base P Series Drives - Analog Monitor (Output) Specs
P Series drives provide 2-channel analog monitor outputs, for drive gain tuning or internal status parameter monitoring.
These analog outputs are 12 bit resolution.
Maximum permissible load current is 2.5mA (or less).
Stabilization time is 15usec.
Update rate for the output values is as follows:
Drive Update Rate
PD-04 8 kHz
PD-10 8 kHz
PD-35 8 kHz
PD-L03-M 8 kHz
PD-L06-M 8 kHz
jw jan 2017
