Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Ethernet/IP Encoders
      • 9000 (Legacy)-
        • ACR Order Code
        • EPL Drive Enable Status
        • ACR9000 Event Counters
        • Ethernet/IP Encoders
        • Maximum USB Cable Length
        • Senary Axis Flags
The ACR90x0's do not currently support Ethernet/IP encoders.
The ACR90x0's currently support only CiA DSP-402 protocol. This is a protocol defined only for the drives and the controllers. All the encoders are defined by the CiA DSP-406 protocol. Ideally all the communication between the drives and the encoder is handled by the Managing Node.
