Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Are Parker IO modules available as NPN?
      • 9000 (Legacy)-
        • ACR Order Code
        • EPL Drive Enable Status
        • ACR9000 Event Counters
        • Ethernet/IP Encoders
        • Maximum USB Cable Length
        • Senary Axis Flags
      • Encoder Velocity
      • Evaluation Underflow error
      • How to receive ASCII data
      • INTCAP
      • MFLOPS vs. MIPS
      • Reboot in startup program
      • Use of AXIS format
      • User Variables
      • Using Encoder 8 or 9 as SRC
      • What is the axis velocity
      • Axis Flag update rate
Parker PIO modules as standard are PNP.
NPN modules are available as custom:
CP*PIO-516-15597      Custom Digital output module for PIO, NPN 4 Outputs
CP*PIO-408-15596      Custom Digital input module for PIO,  NPN 4 Inputs
CP*PIO-436-13771      Custom Digital Input module for PIO,  NPN 8 Inputs
CP*PIO-536-13772      Custom Digital Output module for PIO, NPN 8 Outputs
These can be quoted through your local Parker Automation Technology Center (ATC) full line electromechanical distributor through our custom products quotes via our distributor extranet site.
5/2/17jh
