Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base P Series Accessories - 50 Pin I/O Breakout Module Labels (APC-VSCN1T05)
For customers wanting a copy of the label or to print a new copy of the label that's inserted into the APC-VSCN1T05  (50pin breakout for the Pseries IndexerDrive):
Pseries_50pin_blank.pdf
Pseries_50pin_label.pdf
