Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base MPM Motors - Recommended replacements for MPM72 series: NeoMetric N070
The MPM72 is no longer available. However the NeoMetric N070 series has very similar dimensions and same or better torque & speed. Below is the suggested replacement.
Specs & Speed-Torque Performance of MPM72 series (.zip)
Specs & Speed-Torque Performance of N070 series (.zip)
Below lists the PS style connectors on the NeoMetric. These are a better connector than the MS style connector. The MS is a military Amphenol connector but it's different pinout and gender than the Option1 on the MPM series. MS cables are available but more expensive and longer leadtime than the PS connector cables.
The connectors and pinouts are different so the cables will need to be updated.  The PS connector cables are shown on our website here.
Related FAQ: How to Replace an MPA amplifier?
Full specifications are available on the NeoMetric series servo motor web page and MPM series servo motor web page.
Note if this is a new application we do have newer motors available in similar power levels or if you're open to changing the mechanics the motor is connecting to. Example, if the MPM72 is attaching to a gearhead and it's possible to change the gearhead mounting kit the a PM-FBL or PM-FCL are available. Newer motors have other newer options, such as absolute encoders offered as standard on the Pseries rotary motors. The NeoMetric motors are the closest motor when compared to the MPM72 but to review the system and newer options depending on what you're open to updating on the machine, please contact your local Parker Automation Technology Center (ATC) to discuss.
MPM72 Motor NeoMetric Replacement
MPM721A N0701D Notes
MPM721ASG7G1N N0701DR-NPSN Resolver, No brake
MPM721ATG7G1N N0701DR-NPSN Resolver, No brake
MPM721ASG7JN1N N0701DE-NPSN Encoder, No brake
MPM721ATG7JN1N N0701DE-NPSN Encoder, No brake
MPM721ASG7G1R N0701DR-NPSB Resolver, Brake
MPM721ATG7G1R N0701DR-NPSB Resolver, Brake
MPM721ASG7JN1R N0701DE-NPSB Encoder, Brake
MPM721ATG7JN1R N0701DE-NPSB Encoder, Brake
MPM721B N0701D
MPM721BSG7G1N N0701DR-NPSN Resolver, No brake
MPM721BTG7G1N N0701DR-NPSN Resolver, No brake
MPM721BSG7JN1N N0701DE-NPSN Encoder, No brake
MPM721BTG7JN1N N0701DE-NPSN Encoder, No brake
MPM721BSG7G1R N0701DR-NPSB Resolver, Brake
MPM721BTG7G1R N0701DR-NPSB Resolver, Brake
MPM721BSG7JN1R N0701DE-NPSB Encoder, Brake
MPM721BTG7JN1R N0701DE-NPSB Encoder, Brake
MPM721B N0701D
MPM721CSG7G1N N0701DR-NPSN Resolver, No brake
MPM721CTG7G1N N0701DR-NPSN Resolver, No brake
MPM721CSG7JN1N N0701DE-NPSN Encoder, No brake
MPM721CTG7JN1N N0701DE-NPSN Encoder, No brake
MPM721CSG7G1R N0701DR-NPSB Resolver, Brake
MPM721CTG7G1R N0701DR-NPSB Resolver, Brake
MPM721CSG7JN1R N0701DE-NPSB Encoder, Brake
MPM721CTG7JN1R N0701DE-NPSB Encoder, Brake
MPM722A N0702F
MPM722ASG7G1N N0702FR-NPSN Resolver, No brake
MPM722ATG7G1N N0702FR-NPSN Resolver, No brake
MPM722ASG7JN1N N0702FE-NPSN Encoder, No brake
MPM722ATG7JN1N N0702FE-NPSN Encoder, No brake
MPM722ASG7G1R N0702FR-NPSB Resolver, Brake
MPM722ATG7G1R N0702FR-NPSB Resolver, Brake
MPM722ASG7JN1R N0702FE-NPSB Encoder, Brake
MPM722ATG7JN1R N0702FE-NPSB Encoder, Brake
MPM722B N0702E
MPM722BSG7G1N N0702ER-NPSN Resolver, No brake
MPM722BTG7G1N N0702ER-NPSN Resolver, No brake
MPM722BSG7JN1N N0702EE-NPSN Encoder, No brake
MPM722BTG7JN1N N0702EE-NPSN Encoder, No brake
MPM722BSG7G1R N0702ER-NPSB Resolver, Brake
MPM722BTG7G1R N0702ER-NPSB Resolver, Brake
MPM722BSG7JN1R N0702EE-NPSB Encoder, Brake
MPM722BTG7JN1R N0702EE-NPSB Encoder, Brake
MPM722C N0702E
MPM722CSG7G1N N0702ER-NPSN Resolver, No brake
MPM722CTG7G1N N0702ER-NPSN Resolver, No brake
MPM722CSG7JN1N N0702EE-NPSN Encoder, No brake
MPM722CTG7JN1N N0702EE-NPSN Encoder, No brake
MPM722CSG7G1R N0702ER-NPSB Resolver, Brake
MPM722CTG7G1R N0702ER-NPSB Resolver, Brake
MPM722CSG7JN1R N0702EE-NPSB Encoder, Brake
MPM722CTG7JN1R N0702EE-NPSB Encoder, Brake
MPM723A N0702G
MPM723ASG7G1N N0703GR-NPSN Resolver, No brake
MPM723ATG7G1N N0703GR-NPSN Resolver, No brake
MPM723ASG7JN1N N0703GE-NPSN Encoder, No brake
MPM723ATG7JN1N N0703GE-NPSN Encoder, No brake
MPM723ASG7G1R N0703GR-NPSB Resolver, Brake
MPM723ATG7G1R N0703GR-NPSB Resolver, Brake
MPM723ASG7JN1R N0703GE-NPSB Encoder, Brake
MPM723ATG7JN1R N0703GE-NPSB Encoder, Brake
MPM723B N0703F
MPM723BSG7G1N N0703FR-NPSN Resolver, No brake
MPM723BTG7G1N N0703FR-NPSN Resolver, No brake
MPM723BSG7JN1N N0703FE-NPSN Encoder, No brake
MPM723BTG7JN1N N0703FE-NPSN Encoder, No brake
MPM723BSG7G1R N0703FR-NPSB Resolver, Brake
MPM723BTG7G1R N0703FR-NPSB Resolver, Brake
MPM723BSG7JN1R N0703FE-NPSB Encoder, Brake
MPM723BTG7JN1R N0703FE-NPSB Encoder, Brake
MPM723C N0703F
MPM723CSG7G1N N0703FR-NPSN Resolver, No brake
MPM723CTG7G1N N0703FR-NPSN Resolver, No brake
MPM723CSG7JN1N N0703FE-NPSN Encoder, No brake
MPM723CTG7JN1N N0703FE-NPSN Encoder, No brake
MPM723CSG7G1R N0703FR-NPSB Resolver, Brake
MPM723CTG7G1R N0703FR-NPSB Resolver, Brake
MPM723CSG7JN1R N0703FE-NPSB Encoder, Brake
MPM723CTG7JN1R N0703FE-NPSB Encoder, Brake
MPM724A N0704G
MPM724ASG7G1N N0704GR-NPSN Resolver, No brake
MPM724ATG7G1N N0704GR-NPSN Resolver, No brake
MPM724ASG7JN1N N0704GE-NPSN Encoder, No brake
MPM724ATG7JN1N N0704GE-NPSN Encoder, No brake
MPM724ASG7G1R N0704GR-NPSB Resolver, Brake
MPM724ATG7G1R N0704GR-NPSB Resolver, Brake
MPM724ASG7JN1R N0704GE-NPSB Encoder, Brake
MPM724ATG7JN1R N0704GE-NPSB Encoder, Brake
MPM724B N0704F
MPM724BSG7G1N N0704FR-NPSN Resolver, No brake
MPM724BTG7G1N N0704FR-NPSN Resolver, No brake
MPM724BSG7JN1N N0704FE-NPSN Encoder, No brake
MPM724BTG7JN1N N0704FE-NPSN Encoder, No brake
MPM724BSG7G1R N0704FR-NPSB Resolver, Brake
MPM724BTG7G1R N0704FR-NPSB Resolver, Brake
MPM724BSG7JN1R N0704FE-NPSB Encoder, Brake
MPM724BTG7JN1R N0704FE-NPSB Encoder, Brake
MPM724C N0704F
MPM724CSG7G1N N0704FR-NPSN Resolver, No brake
MPM724CTG7G1N N0704FR-NPSN Resolver, No brake
MPM724CSG7JN1N N0704FE-NPSN Encoder, No brake
MPM724CTG7JN1N N0704FE-NPSN Encoder, No brake
MPM724CSG7G1R N0704FR-NPSB Resolver, Brake
MPM724CTG7G1R N0704FR-NPSB Resolver, Brake
MPM724CSG7JN1R N0704FE-NPSB Encoder, Brake
MPM724CTG7JN1R N0704FE-NPSB Encoder, Brake
5/25/17jh
