Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base IPA Misc - How to Calculate Regeneration
    • IPA Drive/Controller-
      • IPA Hardware - DC Power
For how to calculate regeneration in an application and sizing a braking/ballast/regen resistor, see Appendix B in the Aries amplifier user guide. Click here.
