Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Using a PHM monitor with a headless XPR/XPR2 unit
    • Interact (Legacy)+
    • Interact Xpress+
    • IX / PCA+
    • PHM / PM1 Industrial Monitors (Discontinued)-
      • Is there a Windows7 / Windows 10 driver for my PHM / PM1 touchscreen interface?
      • Using a PHM monitor with a headless XPR/XPR2 unit
      • What can replace a PM1 or PHM industrial touchscreen monitor?
The PHM touchscreen monitor can be used with the headless XPR or XPR2 units as its display and touchscreen.  However, the XPR/XPR2 unit must be configured for this combination first (out of the box it will not be).
Remove the Compact Flash card from the XPR/XPR2 unit and run the flash back utility (see link to Flash Back Archives below).  Find the version that you are using and run the utility in the XRPT&XPR2T folder.  This is the version for use with the PHM external touchscreen.
Flashback Archives
Now transfer your application back to the CF card.  Plug in a VGA cable between the XPR/XPR2 headless unit and the PHM and an RS232 cross over (null modem) cable between the PHM and the COM1 port on the XPR/XPR2 unit.
glh   6/2017
