Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base How to program a Start, Stop, Reset Cold from within a PAC project
      • Programming Tips-
        • ANY Data Type
        • C0046: Identifier 'xxxx' not defined - precompile error in PAM 1.3.0
        • How can I monitor cycle time in the PAC?
        • How do I use function block methods in CFC?
        • How to make comments in PAC software
        • How to program a Start, Stop, Reset Cold from within a PAC project
        • IDE Login Status
        • IDE User Management
        • Known issue with MC_Stop and MC_Home in PAM 1.3.0
        • Programming Tip: Save Time by reusing Code (Export / Import Programs & Function Blocks)
        • Programming Tip: Save Time on Naming Variables through Export/Import Mappings .csv
        • Variable size arrays
To stop, reset cold or start an application from running, a second app would need to be installed as part of the project in Parker Automation Manager (PAM) software. From that project, it could stop/reset/start the main application with the EtherCAT task. This gives users the ability to do this from the project rather than cycling power on the 24volts on the PAC.
Application Manager is a free download from the CoDeSys store:  https://store.codesys.com/application-manager.html
For this sample application, App2 is running and from AppInteract users can stop, reset and start App1 using AppInteract.xStop, AppInteract.xResetCold and AppInteract.xStart respectively.
From the CoDeSys store, download and install Application Manager. Users will need to run PAM as an admin to install the Application Manager package.
ResetPAC_ApplicationManager.zip
Another option with release 1.3, in the PAC Config Tool there is now a Reboot button:  PAC_Config_SystemSettings.jpg
6/16/17jh
