Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base MPP/MPJ Motors - Motor Weights for MPP190 and MPP270 frame motors
MPP190 Frame
MPP1904 = 26.7 kg  (59.0 lbs)
MPP1906 = 35.0 kg (94.5 lbs)
MPP1908 = 40.4 kg (89.0 lbs)
For brake option add 9.70 kg (21.23 lbs)
MPP270 Frame
MPP2706 = 75.8 kg (167.2 lbs)
MPP2708 = 94.3 kg (207.9 lbs)
For brake option add 17.75 kg (39.1 lbs)
