Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base User Variables
        • Axis Flag update rate
        • Encoder Velocity
        • Evaluation Underflow error
        • How to receive ASCII data
        • INTCAP
        • Reboot in startup program
        • Use of AXIS format
        • User Variables
        • Using Encoder 8 or 9 as SRC
        • What is the axis velocity
      • 9000 (Legacy)+
User Variables
See also : ACR Memory Usage
 Products: ACR9000, 9030,9040,9600,9630,9640, Aries Controller (AR-xxCE), IPA
The Acrobasic language in the ACR9xxx, IPA and Aries Controller offers nearly 5000 pre-defined global user variable addresses in a variety of data types. Some of the variables are retained when the controller powers down. The ACR9xxx controllers utilize both FLASH memory and Battery Backed RAM (BBRAM). The Aries Controller utilizes FLASH and non-volatile USER RAM. BBRAM and NV User RAM store values automatically. Storing variable values in FLASH memory requires the use of the FLASH IMAGE command while programs are stopped.
All of the variable types are accessible via:
  • Any AcroBasic program global variables
  • Parker HMI products Interact Xpress and InteractX
  • ComACRserver for PC applications
  • IEC_PLC programs as direct variables or thru function blocks (9600,9630,9640 only)
  • EtherNet/IP
Parameter Range
ACR Data type
IEC Data Type
Retained
Notes
ACR9xx0
IPA, AriesCE
P0-P4095
64-Bit float
REAL
BBRAM or Flash
Flash
Must be dimensioned prior to use. Dimensioning included in ACR-View Configuration Wizard
P4100-P4103
32-Bit Long
DINT, DWORD
No
No
Each parameter contains 32 user flags (BIT128-255)
P4156-P4159
32-Bit Long
DINT, DWORD
No
No
Each parameter contains 32 user flags (BIT1920-2047)
P38912-P39167
32-Bit Long
DINT, DWORD
BBRAM
P38912-38975 saved in User RAM
Available in ACR9000 OS 1.24 and greater. AriesCE OS1.13 or greater
P39168-P39423
32-Bit float
REAL
BBRAM
P39168-39231 saved in User RAM
BIT128-255
Bit
BOOL
No
No
Also accessible as P4100-P4103
BIT1920-2047
Bit
BOOL
No
No
Also accessible as P4156-P4159
User Variables-HMI
  • Tag addressing for variables follow the basic pattern of Channel.Device. Pxxxx for parameters and Channel.Device. BITxxxx
  • When creating the tag Data Type can be left as Default. The driver will assign the correct type automatically
  • 64-bit floats (P0-P4095) will be sent to and from the HMI as 32-bit floats which can result in a loss of precision in some cases.
User Variables-ComAcrServer
  • The ComACRServer library supports controller communications to PC applications in VB, C++, .Net and Labview.
  • Methods included in the ComACRServer allow for reading and writing of parameters individually or in blocks:
  • SetFlag,SetParmFloat,SetParmLong,SetParmLongMask,GetACRCustom,GetACRGroup,GetACRMemory,GetParmAddr
