Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base 6K Misc - Completely Reset the 6K to Factory Default via Hardware
To reset memory on the 6k controller,  remove the battery from inside the unit. It may be easier to slide a business card under the battery (for 30 seconds) than to remove the battery - to prevent breaking the clips.
See link to pdf below with pictures showing the process.
6k4_battery_HW_RESET.pdf
To reset via software, see FAQ below:
https://community.parker.com/technologies/electromechanical-and-drives/w/electromechanical-knowledge-base/151/completely-reset-the-6k-via-software
30June2017 nc
