Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base What motors with what Gemini drive?
Below is the chart that shows the Compumotor Servo Motors and the recommended Gemini drive to run these motors.
MOTOR MODEL NUMBER RECOMMENDED GEMINI DRIVE
SM161A GV-L3E
SM162A
SM231A
SM232A
SM233A
NO701D/F* JO701D/F* GV-U6E
NO702E/F* JO702E/F*
NO703F* JO703F*
NO704F* JO921F
NO921F
NO703G* JO703G* GV-U12
NO704G* JO921G
NO921G JO922G/J
NO922G/J JO923H
NO923H
NO924J
*The NeoMetric Series Size34 has the same electrical characteristics as the Size70. The only difference is the size of the front plate. Please refer to www.parkermotion.com or the J Series, NeoMetric Series, and SM Series catalogs for motor specifications and dimensions.
SMxxxB motors are not compatible with any Gemini Drive!
