Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base MPP/MPJ Motors - Crossover of Allen Bradley Rockwell MPL series motors (460VAC Hiperface) to Parker MPP (640 & larger)
The MPP (MaxPlusPlus) Series is the industry's highest performing servo motor. Utilizing eight-pole segmented lamination technology, the MPP produces more torque in a shorter package. Use MPP motors for higher torque applications, customization options, or when high performance is required.
The MPP Series features a new design that offers lower inertia and higher power, all in a smaller motor package. These brushless servo motors are designed for the demanding applications found in today's high performance servo systems.
The MPP motors feature segmented core technology, which can yield up to 40% higher torque per unit size than conventionally wound servo motors. Potted stators improve heat transfer for better thermal efficiency, resulting in increased torque at the motor shaft.
High-energy neodymium magnets are employed for higher rates of acceleration.
Parker will customize any MPP motor to meet your specific system requirements. Parker does customs like no one else. We are specialists at customs, offering unrivaled custom motor solutions and support.
The MPP/MPJ family of brushless servo motors redefines performance, flexibility, and reliability.
Feedback Notes:
Numerous applications have used the Kinetix drives with the MPP and MPJ series motors with our standard single-speed resolver (41) and 2000-line (pre-quadrature) encoder (1E) with hall sensors.
Absolute Encoder Notes:
The MPP and MPJ with the Compax3 support the full range of the absolute encoders of 4096 turns and support absolute position retention when the drive has been powered off.
Are MPP / MPJ with absolute encoders compatible with Kinetix drives?
MPL series motors with M are a multi-turn Stegmann Hiperface absolute encoder (4096 turns). The MPP series motors with 6S are the same model Stegmann Hiperface absolute encoder (SRM 50). Kinetix drives use a blob file that's sent from the Hiperface absolute encoder for their auto-configuration. The MPP use the standard Hiperface encoder without this blob file. Thus MPP motors with the Stegmann Hiperface multi-turn (6S) or single-turn (9S) are compatible with Parker Compax3 drives with F11 but not Kinetix drives.
Kinetix drives 300 do not support third-party motors. For 350 drives, you can check with your AB representative.
Kinetix 6200 support third-party motors with EnDat with firmware version 1.040:
Kinetix 6200 firmware note 1
Kinetix 6200 firmware note 2
Kinetix 6500 support third-party motors with EnDat with firmware version 2.005:
Kinetix 6500 firmware note 1
Kinetix 6500 firmware note 2
MPP and MPJ servo motors are available with EnDat 2.1 encoder (ECI 1331) and is the 7D order code. ie, MPP0921B7D-NPSN Note the limited Kinetix ability in using the absolute encoder function in power-off (above notes). Note the drive and cable differences per this FAQ if using Parker Compax3:
FAQ: Absolute Encoders and Drive Compatibility
Connector Notes:
Initially the MPL series motors had fixed connectors, Circular Bayonet, Facing Shaft. This was connector 2 in the part numbering: MPL-A330P-MJ22AA. Allen Bradley now has the MPL series with Circular (SpeedTec) DIN connector, right-angle 180 degree rotatable, similar style as the MPP series motor. This is connector 7 in the part numbering: MPL-A330P-MJ72AA
Click here for Compax3 Input and Control Technology Levels  (IxxTxxMxx options)
Disclaimer: This has been developed as a guide for cross referencing MPL motors to Parker motors. The motors should not be used for final motor selection unless reviewed and approved by an automation engineer. The customer is ultimately responsible for their machine design.
To use this table, hold Control key and press F. Text find will appear, something that looks like this:
Enter the MPL motor part number. The Parker motor and drive options are listed as well as the motor power and feedback cables.
460VAC Hiperface
Allen Bradley Rockwell P/N Parker P/N Hiperface feedback Parker Compax3S Single Axis Servo Drive* Parker Compax3M Multi Axis Servo Drive* Parker P/N Resolver feedback Parker Compax3S Single Axis Servo Drive* Parker Compax3M Multi Axis Servo Drive* Motor Power Cable P/N Feedback Cable P/N for Compax3 Feedback Cable P/N flying leads
MPL-B640F MPP1904P
MPL-B640F-MJ22AA MPP1904P6S-KPSN S300V4F11IxxTxxMxx M300D6F11IxxTxxMxx MPP1904P41-KPSN S300V4F10IxxTxxMxx M300D6F10IxxTxxMxx P-4B2-xx F-2B1-xx F-9F1-xx
MPL-B640F-MJ72AA MPP1904P6S-KPSN S300V4F11IxxTxxMxx M300D6F11IxxTxxMxx MPP1904P41-KPSN S300V4F10IxxTxxMxx M300D6F10IxxTxxMxx P-4B2-xx F-2B1-xx F-9F1-xx
MPL-B640F-SJ22AA MPP1904P9S-KPSN S300V4F11IxxTxxMxx M300D6F11IxxTxxMxx MPP1904P41-KPSN S300V4F10IxxTxxMxx M300D6F10IxxTxxMxx P-4B2-xx F-2B1-xx F-9F1-xx
MPL-B640F-SJ72AA MPP1904P9S-KPSN S300V4F11IxxTxxMxx M300D6F11IxxTxxMxx MPP1904P41-KPSN S300V4F10IxxTxxMxx M300D6F10IxxTxxMxx P-4B2-xx F-2B1-xx F-9F1-xx
MPL-B640F-MJ24AA MPP1904P6S-KPSB S300V4F11IxxTxxMxx M300D6F11IxxTxxMxx MPP1904P41-KPSB S300V4F10IxxTxxMxx M300D6F10IxxTxxMxx P-4B2-xx F-2B1-xx F-9F1-xx
MPL-B640F-MJ74AA MPP1904P6S-KPSB S300V4F11IxxTxxMxx M300D6F11IxxTxxMxx MPP1904P41-KPSB S300V4F10IxxTxxMxx M300D6F10IxxTxxMxx P-4B2-xx F-2B1-xx F-9F1-xx
MPL-B640F-SJ24AA MPP1904P9S-KPSB S300V4F11IxxTxxMxx M300D6F11IxxTxxMxx MPP1904P41-KPSB S300V4F10IxxTxxMxx M300D6F10IxxTxxMxx P-4B2-xx F-2B1-xx F-9F1-xx
MPL-B640F-SJ74AA MPP1904P9S-KPSB S300V4F11IxxTxxMxx M300D6F11IxxTxxMxx MPP1904P41-KPSB S300V4F10IxxTxxMxx M300D6F10IxxTxxMxx P-4B2-xx F-2B1-xx F-9F1-xx
MPL-B660F MPP1906P
MPL-B660F-MJ22AA MPP1906P6S-KPSN S300V4F11IxxTxxMxx M300D6F11IxxTxxMxx MPP1906P41-KPSN S300V4F10IxxTxxMxx M300D6F10IxxTxxMxx P-4B2-xx F-2B1-xx F-9F1-xx
MPL-B660F-MJ72AA MPP1906P6S-KPSN S300V4F11IxxTxxMxx M300D6F11IxxTxxMxx MPP1906P41-KPSN S300V4F10IxxTxxMxx M300D6F10IxxTxxMxx P-4B2-xx F-2B1-xx F-9F1-xx
MPL-B660F-SJ22AA MPP1906P9S-KPSN S300V4F11IxxTxxMxx M300D6F11IxxTxxMxx MPP1906P41-KPSN S300V4F10IxxTxxMxx M300D6F10IxxTxxMxx P-4B2-xx F-2B1-xx F-9F1-xx
MPL-B660F-SJ72AA MPP1906P9S-KPSN S300V4F11IxxTxxMxx M300D6F11IxxTxxMxx MPP1906P41-KPSN S300V4F10IxxTxxMxx M300D6F10IxxTxxMxx P-4B2-xx F-2B1-xx F-9F1-xx
MPL-B660F-MJ24AA MPP1906P6S-KPSB S300V4F11IxxTxxMxx M300D6F11IxxTxxMxx MPP1906P41-KPSB S300V4F10IxxTxxMxx M300D6F10IxxTxxMxx P-4B2-xx F-2B1-xx F-9F1-xx
MPL-B660F-MJ74AA MPP1906P6S-KPSB S300V4F11IxxTxxMxx M300D6F11IxxTxxMxx MPP1906P41-KPSB S300V4F10IxxTxxMxx M300D6F10IxxTxxMxx P-4B2-xx F-2B1-xx F-9F1-xx
MPL-B660F-SJ24AA MPP1906P9S-KPSB S300V4F11IxxTxxMxx M300D6F11IxxTxxMxx MPP1906P41-KPSB S300V4F10IxxTxxMxx M300D6F10IxxTxxMxx P-4B2-xx F-2B1-xx F-9F1-xx
MPL-B660F-SJ74AA MPP1906P9S-KPSB S300V4F11IxxTxxMxx M300D6F11IxxTxxMxx MPP1906P41-KPSB S300V4F10IxxTxxMxx M300D6F10IxxTxxMxx P-4B2-xx F-2B1-xx F-9F1-xx
MPL-B680D MPP1908N
MPL-B680D-MJ22AA MPP1908N6S-KPSN S300V4F11IxxTxxMxx M300D6F11IxxTxxMxx MPP1908N41-KPSN S300V4F10IxxTxxMxx M300D6F10IxxTxxMxx P-4B2-xx F-2B1-xx F-9F1-xx
MPL-B680D-MJ72AA MPP1908N6S-KPSN S300V4F11IxxTxxMxx M300D6F11IxxTxxMxx MPP1908N41-KPSN S300V4F10IxxTxxMxx M300D6F10IxxTxxMxx P-4B2-xx F-2B1-xx F-9F1-xx
MPL-B680D-SJ22AA MPP1908N9S-KPSN S300V4F11IxxTxxMxx M300D6F11IxxTxxMxx MPP1908N41-KPSN S300V4F10IxxTxxMxx M300D6F10IxxTxxMxx P-4B2-xx F-2B1-xx F-9F1-xx
MPL-B680D-SJ72AA MPP1908N9S-KPSN S300V4F11IxxTxxMxx M300D6F11IxxTxxMxx MPP1908N41-KPSN S300V4F10IxxTxxMxx M300D6F10IxxTxxMxx P-4B2-xx F-2B1-xx F-9F1-xx
MPL-B680D-MJ24AA MPP1908N6S-KPSB S300V4F11IxxTxxMxx M300D6F11IxxTxxMxx MPP1908N41-KPSB S300V4F10IxxTxxMxx M300D6F10IxxTxxMxx P-4B2-xx F-2B1-xx F-9F1-xx
MPL-B680D-MJ74AA MPP1908N6S-KPSB S300V4F11IxxTxxMxx M300D6F11IxxTxxMxx MPP1908N41-KPSB S300V4F10IxxTxxMxx M300D6F10IxxTxxMxx P-4B2-xx F-2B1-xx F-9F1-xx
MPL-B680D-SJ24AA MPP1908N9S-KPSB S300V4F11IxxTxxMxx M300D6F11IxxTxxMxx MPP1908N41-KPSB S300V4F10IxxTxxMxx M300D6F10IxxTxxMxx P-4B2-xx F-2B1-xx F-9F1-xx
MPL-B680D-SJ74AA MPP1908N9S-KPSB S300V4F11IxxTxxMxx M300D6F11IxxTxxMxx MPP1908N41-KPSB S300V4F10IxxTxxMxx M300D6F10IxxTxxMxx P-4B2-xx F-2B1-xx F-9F1-xx
MPL-B680F MPP1908P
MPL-B680F-MJ22AA MPP1908P6S-KPSN S300V4F11IxxTxxMxx M300D6F11IxxTxxMxx MPP1908P41-KPSN S300V4F10IxxTxxMxx M300D6F10IxxTxxMxx P-4B2-xx F-2B1-xx F-9F1-xx
MPL-B680F-MJ72AA MPP1908P6S-KPSN S300V4F11IxxTxxMxx M300D6F11IxxTxxMxx MPP1908P41-KPSN S300V4F10IxxTxxMxx M300D6F10IxxTxxMxx P-4B2-xx F-2B1-xx F-9F1-xx
MPL-B680F-SJ22AA MPP1908P9S-KPSN S300V4F11IxxTxxMxx M300D6F11IxxTxxMxx MPP1908P41-KPSN S300V4F10IxxTxxMxx M300D6F10IxxTxxMxx P-4B2-xx F-2B1-xx F-9F1-xx
MPL-B680F-SJ72AA MPP1908P9S-KPSN S300V4F11IxxTxxMxx M300D6F11IxxTxxMxx MPP1908P41-KPSN S300V4F10IxxTxxMxx M300D6F10IxxTxxMxx P-4B2-xx F-2B1-xx F-9F1-xx
MPL-B680F-MJ24AA MPP1908P6S-KPSB S300V4F11IxxTxxMxx M300D6F11IxxTxxMxx MPP1908P41-KPSB S300V4F10IxxTxxMxx M300D6F10IxxTxxMxx P-4B2-xx F-2B1-xx F-9F1-xx
MPL-B680F-MJ74AA MPP1908P6S-KPSB S300V4F11IxxTxxMxx M300D6F11IxxTxxMxx MPP1908P41-KPSB S300V4F10IxxTxxMxx M300D6F10IxxTxxMxx P-4B2-xx F-2B1-xx F-9F1-xx
MPL-B680F-SJ24AA MPP1908P9S-KPSB S300V4F11IxxTxxMxx M300D6F11IxxTxxMxx MPP1908P41-KPSB S300V4F10IxxTxxMxx M300D6F10IxxTxxMxx P-4B2-xx F-2B1-xx F-9F1-xx
MPL-B680F-SJ74AA MPP1908P9S-KPSB S300V4F11IxxTxxMxx M300D6F11IxxTxxMxx MPP1908P41-KPSB S300V4F10IxxTxxMxx M300D6F10IxxTxxMxx P-4B2-xx F-2B1-xx F-9F1-xx
MPL-B860D MPP2306N Discontinued 2011
MPL-B880C MPP2308N Discontinued 2011
MPL-B880D MPP2308P Discontinued 2011
MPL-B960B MPP2706M
MPL-B960B-MJ22AA MPP2706M6S-KPSN S300V4F11IxxTxxMxx M300D6F11IxxTxxMxx MPP2706M41-KPSN S300V4F10IxxTxxMxx M300D6F10IxxTxxMxx P-4B2-xx F-2B1-xx F-9F1-xx
MPL-B960B-MJ72AA MPP2706M6S-KPSN S300V4F11IxxTxxMxx M300D6F11IxxTxxMxx MPP2706M41-KPSN S300V4F10IxxTxxMxx M300D6F10IxxTxxMxx P-4B2-xx F-2B1-xx F-9F1-xx
MPL-B960B-SJ22AA MPP2706M9S-KPSN S300V4F11IxxTxxMxx M300D6F11IxxTxxMxx MPP2706M41-KPSN S300V4F10IxxTxxMxx M300D6F10IxxTxxMxx P-4B2-xx F-2B1-xx F-9F1-xx
MPL-B960B-SJ72AA MPP2706M9S-KPSN S300V4F11IxxTxxMxx M300D6F11IxxTxxMxx MPP2706M41-KPSN S300V4F10IxxTxxMxx M300D6F10IxxTxxMxx P-4B2-xx F-2B1-xx F-9F1-xx
MPL-B960B-MJ24AA MPP2706M6S-KPSB S300V4F11IxxTxxMxx M300D6F11IxxTxxMxx MPP2706M41-KPSB S300V4F10IxxTxxMxx M300D6F10IxxTxxMxx P-4B2-xx F-2B1-xx F-9F1-xx
MPL-B960B-MJ74AA MPP2706M6S-KPSB S300V4F11IxxTxxMxx M300D6F11IxxTxxMxx MPP2706M41-KPSB S300V4F10IxxTxxMxx M300D6F10IxxTxxMxx P-4B2-xx F-2B1-xx F-9F1-xx
MPL-B960B-SJ24AA MPP2706M9S-KPSB S300V4F11IxxTxxMxx M300D6F11IxxTxxMxx MPP2706M41-KPSB S300V4F10IxxTxxMxx M300D6F10IxxTxxMxx P-4B2-xx F-2B1-xx F-9F1-xx
MPL-B960B-SJ74AA MPP2706M9S-KPSB S300V4F11IxxTxxMxx M300D6F11IxxTxxMxx MPP2706M41-KPSB S300V4F10IxxTxxMxx M300D6F10IxxTxxMxx P-4B2-xx F-2B1-xx F-9F1-xx
MPL-B960C MPP2706N
MPL-B960C-MJ22AA MPP2706N6S-KPSN H050V4F11IxxTxxMxx Use C3H050V4 MPP2706N41-KPSN H050V4F10IxxTxxMxx Use C3H050V4 P-6B2-xx F-2B1-xx F-9F1-xx
MPL-B960C-MJ72AA MPP2706N6S-KPSN H050V4F11IxxTxxMxx Use C3H050V4 MPP2706N41-KPSN H050V4F10IxxTxxMxx Use C3H050V4 P-6B2-xx F-2B1-xx F-9F1-xx
MPL-B960C-SJ22AA MPP2706N9S-KPSN H050V4F11IxxTxxMxx   MPP2706N41-KPSN H050V4F10IxxTxxMxx   P-6B2-xx F-2B1-xx F-9F1-xx
MPL-B960C-SJ72AA MPP2706N9S-KPSN H050V4F11IxxTxxMxx   MPP2706N41-KPSN H050V4F10IxxTxxMxx   P-6B2-xx F-2B1-xx F-9F1-xx
MPL-B960C-MJ24AA MPP2706N6S-KPSB H050V4F11IxxTxxMxx   MPP2706N41-KPSB H050V4F10IxxTxxMxx   P-6B2-xx F-2B1-xx F-9F1-xx
MPL-B960C-MJ74AA MPP2706N6S-KPSB H050V4F11IxxTxxMxx   MPP2706N41-KPSB H050V4F10IxxTxxMxx   P-6B2-xx F-2B1-xx F-9F1-xx
MPL-B960C-SJ24AA MPP2706N9S-KPSB H050V4F11IxxTxxMxx   MPP2706N41-KPSB H050V4F10IxxTxxMxx   P-6B2-xx F-2B1-xx F-9F1-xx
MPL-B960C-SJ74AA MPP2706N9S-KPSB H050V4F11IxxTxxMxx   MPP2706N41-KPSB H050V4F10IxxTxxMxx   P-6B2-xx F-2B1-xx F-9F1-xx
MPL-B980B MPP2708L
MPL-B980B-MJ22AA MPP2708L6S-KPSN S300V4F11IxxTxxMxx M300D6F11IxxTxxMxx MPP2708L41-KPSN S300V4F10IxxTxxMxx M300D6F10IxxTxxMxx P-4B2-xx F-2B1-xx F-9F1-xx
MPL-B980B-MJ72AA MPP2708L6S-KPSN S300V4F11IxxTxxMxx M300D6F11IxxTxxMxx MPP2708L41-KPSN S300V4F10IxxTxxMxx M300D6F10IxxTxxMxx P-4B2-xx F-2B1-xx F-9F1-xx
MPL-B980B-SJ22AA MPP2708L9S-KPSN S300V4F11IxxTxxMxx M300D6F11IxxTxxMxx MPP2708L41-KPSN S300V4F10IxxTxxMxx M300D6F10IxxTxxMxx P-4B2-xx F-2B1-xx F-9F1-xx
MPL-B980B-SJ72AA MPP2708L9S-KPSN S300V4F11IxxTxxMxx M300D6F11IxxTxxMxx MPP2708L41-KPSN S300V4F10IxxTxxMxx M300D6F10IxxTxxMxx P-4B2-xx F-2B1-xx F-9F1-xx
MPL-B980B-MJ24AA MPP2708L6S-KPSB S300V4F11IxxTxxMxx M300D6F11IxxTxxMxx MPP2708L41-KPSB S300V4F10IxxTxxMxx M300D6F10IxxTxxMxx P-4B2-xx F-2B1-xx F-9F1-xx
MPL-B980B-MJ74AA MPP2708L6S-KPSB S300V4F11IxxTxxMxx M300D6F11IxxTxxMxx MPP2708L41-KPSB S300V4F10IxxTxxMxx M300D6F10IxxTxxMxx P-4B2-xx F-2B1-xx F-9F1-xx
MPL-B980B-SJ24AA MPP2708L9S-KPSB S300V4F11IxxTxxMxx M300D6F11IxxTxxMxx MPP2708L41-KPSB S300V4F10IxxTxxMxx M300D6F10IxxTxxMxx P-4B2-xx F-2B1-xx F-9F1-xx
MPL-B980B-SJ74AA MPP2708L9S-KPSB S300V4F11IxxTxxMxx M300D6F11IxxTxxMxx MPP2708L41-KPSB S300V4F10IxxTxxMxx M300D6F10IxxTxxMxx P-4B2-xx F-2B1-xx F-9F1-xx
MPL-B980C MPP2708M
MPL-B980C-MJ22AA MPP2708M6S-KPSN H050V4F11IxxTxxMxx Use C3H050V4 MPP2708M41-KPSN H050V4F10IxxTxxMxx Use C3H050V4 P-6B2-xx F-2B1-xx F-9F1-xx
MPL-B980C-MJ72AA MPP2708M6S-KPSN H050V4F11IxxTxxMxx Use C3H050V4 MPP2708M41-KPSN H050V4F10IxxTxxMxx Use C3H050V4 P-6B2-xx F-2B1-xx F-9F1-xx
MPL-B980C-SJ22AA MPP2708M9S-KPSN H050V4F11IxxTxxMxx   MPP2708M41-KPSN H050V4F10IxxTxxMxx   P-6B2-xx F-2B1-xx F-9F1-xx
MPL-B980C-SJ72AA MPP2708M9S-KPSN H050V4F11IxxTxxMxx   MPP2708M41-KPSN H050V4F10IxxTxxMxx   P-6B2-xx F-2B1-xx F-9F1-xx
MPL-B980C-MJ24AA MPP2708M6S-KPSB H050V4F11IxxTxxMxx   MPP2708M41-KPSB H050V4F10IxxTxxMxx   P-6B2-xx F-2B1-xx F-9F1-xx
MPL-B980C-MJ74AA MPP2708M6S-KPSB H050V4F11IxxTxxMxx   MPP2708M41-KPSB H050V4F10IxxTxxMxx   P-6B2-xx F-2B1-xx F-9F1-xx
MPL-B980C-SJ24AA MPP2708M9S-KPSB H050V4F11IxxTxxMxx   MPP2708M41-KPSB H050V4F10IxxTxxMxx   P-6B2-xx F-2B1-xx F-9F1-xx
MPL-B980C-SJ74AA MPP2708M9S-KPSB H050V4F11IxxTxxMxx   MPP2708M41-KPSB H050V4F10IxxTxxMxx   P-6B2-xx F-2B1-xx F-9F1-xx
MPL-B980D MPP2708N
MPL-B980D-MJ22AA MPP2708N6S-KPSN H050V4F11IxxTxxMxx Use C3H050V4 MPP2708N41-KPSN H050V4F10IxxTxxMxx Use C3H050V4 P-6B2-xx F-2B1-xx F-9F1-xx
MPL-B980D-MJ72AA MPP2708N6S-KPSN H050V4F11IxxTxxMxx Use C3H050V4 MPP2708N41-KPSN H050V4F10IxxTxxMxx Use C3H050V4 P-6B2-xx F-2B1-xx F-9F1-xx
MPL-B980D-SJ22AA MPP2708N9S-KPSN H050V4F11IxxTxxMxx   MPP2708N41-KPSN H050V4F10IxxTxxMxx   P-6B2-xx F-2B1-xx F-9F1-xx
MPL-B980D-SJ72AA MPP2708N9S-KPSN H050V4F11IxxTxxMxx   MPP2708N41-KPSN H050V4F10IxxTxxMxx   P-6B2-xx F-2B1-xx F-9F1-xx
MPL-B980D-MJ24AA MPP2708N6S-KPSB H050V4F11IxxTxxMxx   MPP2708N41-KPSB H050V4F10IxxTxxMxx   P-6B2-xx F-2B1-xx F-9F1-xx
MPL-B980D-MJ74AA MPP2708N6S-KPSB H050V4F11IxxTxxMxx   MPP2708N41-KPSB H050V4F10IxxTxxMxx   P-6B2-xx F-2B1-xx F-9F1-xx
MPL-B980D-SJ24AA MPP2708N9S-KPSB H050V4F11IxxTxxMxx   MPP2708N41-KPSB H050V4F10IxxTxxMxx   P-6B2-xx F-2B1-xx F-9F1-xx
MPL-B980D-SJ74AA MPP2708N9S-KPSB H050V4F11IxxTxxMxx   MPP2708N41-KPSB H050V4F10IxxTxxMxx   P-6B2-xx F-2B1-xx F-9F1-xx
