Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base General - Rated Bearing Loads for Compumotor Servos
The rated radial and axial bearing load for all SM, SE, NeoMetric, J-Series and BE servo motors are conservatively specified as follows:
Rated Radial Bearing Load - 10 lbs
Rated Bearing Side Load - 10 in-lbs
Rated Axial Bearing Load - 10 lbs
The rated radial and axial bearing load for all M-series servo motors are conservatively specified as follows:
Rated Radial Load Rated Axial Load
Lbs N Lbs N
M1053 168 750 34 150
M1054 174 775 34 150
M1453 229 1020 46 205
M1454 240 1070 48 214
M1455 247 1100 49 218
M2052 596 2650 119 529
M2053 627 2790 125 556
M2054 650 2890 130 578
All bearing load values are based on standard L10 Bearing Life calculations. As such, all Compumotor servo motors are specified to operate at any speed up to their rated speed with the aforementioned bearing loads applied at the motor shaft. Actual L10 life depends on motor size and operating speed in addition to shaft loading.
While the above bearing load values are what Compumotor motors are specified as being easily able to handle, the L10 bearing life expectancy can also be calculated for applications where the axial and/or radial bearing load of 10 lbs is exceeded. For more information, inquire with the Compumotor Applications Department at 1-800-358-9070.
