Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Parker SBC Replacement products
  • Other-
    • -E Motor Option
    • C/CX Suggested Replacements
    • Cage Code
    • Controller Cable Drawings
    • Custom Products
    • Daisy chaining AR-C
    • Drive Input Power
    • Dumping the 3000 memory.
    • EDC TDC XDC VRP PMC
    • Encoder or Resolver?
    • Ferrite absorber
    • How Much Power Do I Need?
    • Inertia Ratio
    • KH/KS Error 62
    • KH/KS Motors
    • QM Series Motor Information
    • Smart Encoder Compatibility
    • Software for the SV
    • Torque Margin
    • Transformer Specs
    • Upgrading A/AX Systems
    • What is CE, EMC and LVD?
Several Parker SBC products recently are no longer available. Below are suggested replacement products.
These products are from the Parker Electromechanical Europe division. Support in North America is limited as these are not standard products sold in North America.
Full specifications, software and user guides are available on Parker EME's website: Servo Drives and Servo Drive/Controllers | Parker
Replacements are available in North America. These products can be purchased through your local Parker Automation Technology Center distributor through our custom products group.
For customers in North America willing and able to upgrade the servo amplifier and/or controllers, the Aries, Compax3 servo amplifiers and ACR9000 series controllers offer higher performance in a small package and powerful and flexible machine control. Please contact your local Parker ATC for recommended replacements.
Drive Obsolete Voltage supply General characteristics PLC BUS Suggested replacement Voltage supply General characteristics PLC BUS (*) Progr. Param option
LVD 230 8IN-6OUT(+relay) 64 SBC >>>>> SLVD-N 230 4IN-2OUT 256 S C D E5 Similar -
HPD 400 8IN-6OUT(+relay) 64 SBC >>>>> HID 230 400 5IN(+en)-2OUT(+relay) 256 S D E5 Different I/O
HPD H3 400 8IN-6OUT(+relay) 64 SBC >>>>> HID-X 230 400 5IN(+en)-2OUT(+relay) 256 S D E5 Different I/O
HPD + EC4 (**) 400 8IN-6OUT(+relay) +EC4 64 SBC >>>>> HID (after verification) 230 400 5IN(+en)-2OUT(+relay) 256 S D E5 Different I/O + LL
sLVD 230 2IN-2OUT 128 CAN/SBC >>>>> SLVD-N 230 400 4IN-2OUT 256 S C D E5 Equal Adapter
SPD2,5,8 230 400 4IN-2OUT 128 CAN/SBC >>>>> SPD-N2,5,8 230 400 4IN(+2)-2OUT 256 S C D E5 Equal -
SPD16,24 400 4IN-2OUT 128 CAN/SBC >>>>> HID 230 400 5IN(+en)-2OUT(+relay) 256 S D E5 Different -
TWIN2,5,8 230 400 4IN-2OUT 128 CAN/SBC >>>>> TWIN-N2,5,8 230 400 4IN(+2)-2OUT 256 S C D E5 Equal -
(*) S: SBCCAN; C: CANopen DS301; D: CANopen DS402; E5: EtherCAT
(**) special application; to substitute review the application.
Full Replacement Details
Note for sLVD installations, there is an adapter allowing the newer sLVD-N as a replacement:
sLVD-N to sLVD adapter
This adapter is available with part number: CP*ADP-SLVDN-14716
15NOV2021 Removed dead links.
