Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base VM15 and VM25 Terminal Breakout Modules
  • Other-
    • -E Motor Option
    • C/CX Suggested Replacements
    • Cage Code
    • Controller Cable Drawings
    • Custom Products
    • Daisy chaining AR-C
    • Drive Input Power
    • Dumping the 3000 memory.
    • EDC TDC XDC VRP PMC
    • Encoder or Resolver?
    • Ferrite absorber
    • How Much Power Do I Need?
    • Inertia Ratio
    • KH/KS Error 62
    • KH/KS Motors
    • Parker Electronic Motion and Control Division (EMC) - Industrial Products Warranty
    • QM Series Motor Information
    • Software for the SV
    • Torque Margin
    • Transformer Specs
    • Upgrading A/AX Systems
    • What is CE, EMC and LVD?
VM15
There are 2 different versions of the VM15, 15 position cage clamp, DIN Rail mount, breakout modules. The VM15 module has 16 connections, pins 1-15, and a shield (S) connection to the housing of the connector on the module. This connector is a standard (2 row) 15 position male D-Subminiature style. The module is the same between both versions; the difference is the cable that comes with the module.
VM15 (new)
VM15 (old)
Height (from top of DIN rail), in (mm)
1.3 (34)
2.5(61)
Width, in (mm)
1.7 (43)
2.0 (50.4)
Length, in (mm)
3.3 (85)
3.62(92)
Connectors
Fixed cage-clamp
fixed screw-terminals
Solder Points per pin
0
2
DIN35-rail mounting clips
Yes
Yes
overall cabinet depth with cable-bend radius, in (mm)
3.5 (89)
5 (127)
Colors
Green/Gray
Red/Black
Operating Voltage
AC/DC 125V
Ambient Operating Temperature
-20 to +50C
Nominal Current
2A
Wire Connection
AWG28 to 12
71-021483-02, 71-021483-05 and 71-021483-10 are the 2-foot, 5-foot and 10-foot female cables. Spares can be purchased separately.
Drawing of 71-021483-xx cable (pdf)
71-021484-02, 71-021484-05 and 71-021484-10 are the 2-foot, 5-foot and 10-foot male cables. Spares can be purchased separately.
Drive
Connector/ Description
Module/Cable
Compax3
X11  Reference (Analog I/O, Aux Encoder)
VM15-MC-XX
Compax3
X12  I/O (Digital I/O)
VM15-FC-XX
Compax3
X13  Feedback
VM15-MC-XX
Compax3
X22  Extended I/O (Digital I/O)
VM15-FC-XX
Aries
Motor Feedback Connector
VM-15-MC-XX
ViX
X2 : Motor Feedback
VM-15-MC-XX
ViX
X4 : Control & Auxiliary I/O
VM-15-MC-XX
ViX
X5: User Input/Output
VM15-FC-XX
Note: While the module can support the wire gauge, current, and voltage listed above, the molded cables that come with these modules use 24 AWG conductors. Thus, the connections to this module should not exceed the limitations of a 24 AWG conductor.
VM15-FC-02  VM15-FC-05  VM15-FC-10  VM15-MC-02  VM15-MC-05  VM15-MC-10  VM15-NC-00
VM25
VM25-MC-02  is a 25pin breakout module with 2.5-foot cable, male cable, replaces VM25
VM25-NC-00 is a 25pin breakout module only (no cable)
71-031021-02 is the 25pin to 25pin cable, 2.5-foot cable that can be purchased as spares.
Drawing of 71-031021-xx (pdf)
VM25-MC-02 (new)
VM25 (old)
0.75 (19)
2.75 (70)
Width, in (mm)
3.1 (79)
3.0 (76)
Length, in (mm)
2.5 (63.5)
3.62 (92)
Connectors
Fixed cage-clamp
Removable screw-terminals
2
6
Cable Length, ft (mm)
2.5 (762)
2.0 (610)
Yes
Yes
3.5 (89)
5 (127)
Colors
Green/Gray
Blue/Black
Operating Voltage
AC/DC 125V
-20 to +50C
Wire Connection
AWG28 to 12
Note: While the module can support the wire gauge, current, and voltage listed above, the molded cable that comes with this module uses 26 AWG conductors. Thus, the connections to this module should not exceed the limitations of a 26 AWG conductor.
Obsolete VM15 information for reference:
VM15  The cable that comes with this module is part number 71-016949-02 (can be purchased separately). This is a standard (2 row) 15 position male D-Subminiature connector to a standard (2 row) 15 position female D-Subminiature connector on each end of a 2 foot cable. This was a screw-terminal module.
VM15-PF The cable that comes with this module is part number 71-021483-02 (can be purchased separately). This is a standard (2 row) 15 position female D-Subminiature connector to a high density (3 row) 15 position female D-Subminiature connector on each end of a 2 foot cable. This was a screw-terminal module. This is replaced with a VM15-FC-02.
VM15-PM The cable that comes with a this module is part number 71-021484-02 (can be purchased separately). This is a standard (2 row) 15 position female D-Subminiature connector to a high density (3 row) 15 position male D-Submniniature connector on each end of a 2 foot cable. This was a screw-terminal module. This is replaced with the VM15-MC-02.
Obsolete Miscellaneous Module Specifications:
Wire range: 26 - 12 AWG
Voltage rating: 125 VAC
Current rating: 2.5 A
DIN Mounting rail: 35 x 7.5 mm
