Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Connecting a Parker IO (PIO) to an ACR9000
      • 9000 (Legacy)-
        • ACR Order Code
        • EPL Drive Enable Status
        • ACR9000 Event Counters
        • Ethernet/IP Encoders
        • Maximum USB Cable Length
        • Senary Axis Flags
When using a PIO 337 or 347, there are 4 wires that need to be connected. One side has the ACR9000 connection and the other side has 4 flying leads. Shown below in the table are the connections that need to be made. For the CAN BUS connection, pin 1 is on top and pin 5 is on the bottom.
ACR9000 pins Color Function BUS coupler connection
2 White CAN_L (CAN Signal Low) 4
3 Black CAN_GND 5
7 Blue CAN_H (CAN Signal High) 2
5 Clear Drain,Shield 3
