Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Aries ARxxSE/ARxxSR tuning for Step/Direction
    • Aries Drive (Discontinued)-
      • Controller (CE)+
      • Drive only (AE,AR, SE, SR)-
        • Hall-only Commutation
        • Meaning of the Status LEDs
      • EPL+
      • Aries Brake Delay
      • E27 Bridge Hardware Fault
      • Manual Alignment Procedure
      • Aries drive won't enable
      • Selecting a Fuse
To Tune the Aries Step/Direction Drive, use the Aries Support Tool software and put the Control Loop in "Tune Position Loop" mode.
See hardware installation guide for description of tuning parameters.
Page 78, Tuning.  See link below.
Aries_ug_revg.pdf
From the Terminal Emulator, you can send commands to look at the actual values of the commanded encoder count (TPC) vs. actual encoder count (TPE) to determine percentage of following error.
