Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Replacing old HMIs that run Interact
    • Interact (Legacy)-
      • CTC and i-Motors
      • TCP/IP open port failure
      • HMI Battery Replacements
      • INTERACT How to Order
      • Which HMI runs Interact?
    • Interact Xpress+
    • IXA / PCA+
If you have an Old HMI that runs Interact, see the document below that describes the recommended upgrade and other requirements.
Replacing old HMIs that run Interact.pdf
