Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base IPA Software - Basic Tuning using ACR-View
    • IPA Drive/Controller-
      • IPA Hardware - DC Power
Using ACRView & its Oscilloscope for Basic Tuning
This short document describes how to do basic tuning for the following hardware:
  • IPA IPA04-HC/IPA15-HC
  • ACR9000/9030/9600/9040
  • Aries ArxxCE controllers
See link below:
Basic IPA Tuning
It is highly recommended to view a short 16 minute YouTube video that takes you step-by-step through the tuning process.See link below:
ACR-View ServoTuner Video - YouTube
There is a more advanced document titled ACR9000_Torque_Tuning.pdf that describes every tuning parameter in detail and may need to be referred to if the basic tuning is not sufficient. See link below:
Advanced Tuning with ACRView
