Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base P Series Motors - Temperature Protection
Does the P Series motors have a temperature switch or thermistor?
No.  However, the drive uses the motor's electrical characteristics and uses a thermal model to predict the motor's temperature and will shut-off power to the drive if it determines the motor is overheating.
