Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base WebVisualization not working in PAC terminal (PTA)
Within the Visualization Manager, select Activate multitouch handling for use with the PAC terminal (PTA) HMI.
This setting wouldn't affect an internet browser and users may see the web visualization working on their development PC in an internet browser but not the PTA unless this is selected.
11/6/17jh
