Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Converting .001 file types to .prj file type
  • AC/DC Industrial Drives-
    • AC890 Series-
    • AC15/AC20+
    • DESAT (OVER I) Fault
This document will describe the procedure to convert the .001 file type used by DSD/DSE890 (version 2.X or earlier) to the .prj file type used by DSE890 version 3.X or later.
1.)Open Windows Explorer and navigate to the following folder C:\ssd_link\CONFIGS. Make sure that the .001 file that you are trying to convert is located here.
2.) Open MANAGER and import the .001 file that you are trying to convert. You should see a message similar to the one below. Selecting Import Read or Import Read/Write will depend on how the file was initially saved and if it has the Read/Write token, follow this through out the process.
3.) Export this same project in MANAGER. Use the file name that is in the scratch pad to ID the CATEGORY NAME and PROJECT NAME. When the window pops up prompting where to save the file make sure to save the file in the same the C:\ssd_link\ folder and to delete .001 extension from the file name.
4.) Open DSE890, Click on PROJECT -> MANAGE -> IMPORT find the FILE of the same project name that was just exported from manager and click OPEN, all file types must be selected to see the file.
5.) Once the file is imported into DSE890 Click on PROJECT -> MANAGE -> EXPORT and save the file as a .prj
  • DSELite
  • dse890
