Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Compax3 Hardware - Wiring for Apex Motors and Motor Files
Compax 3 Feedback
X 13 Connector
Apex Resolver Cable
Input
Designation
1
2
3
4
Brown
REFres+
5
Yellow
+5V
6
7
Blue
SIN -
8
Green
SIN +
9
10
Orange
Tmot
11
Black
COS -
12
Red
COS +
13
14
15
White
REFres-
Compax 3
Apex Motor
U
Orange
V
Blue
W
Grey
PE
Green
Motor files to import into the Compax3 ServoManager software:
Apex600_C3_Files_xml.zip
10/7/15jh added .zip
