Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base P Series Drives - What is N input pin next to L1, L2, L3?
N pin is Negative side of bus caps.
It is not a neutral for the AC input and not connected to earth ground (see user manual for the AC input connections).
The AC earth ground is the chassis ground on the heatsink.
Connecting this to earth ground will cause the drive to fail and would need to be replaced.
1/3/18jh
