Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base MPP/MPJ Motors - Feedback data made available to the user when using Hiperface DSL in MPP servo motor (feedback option 6H)
Introduction
Parker MPP motors offer many feedback options including resolver and incremental, single-turn absolute, and multi-turn absolute encoders. Our model nomenclature follows the pattern MPPaaabcdd-xyyz where “dd” is the feedback device parameter, and the Hiperface DSL parameter is “6H.”
The Hiperface DSL device operates at 12-bit multi-turn resolution and 18-bit resolution per turn. One of the primary benefits of using Hiperface DSL is the fact that all feedback data is sent to the drive using only two wires. On top of that, those two wires are bundled with the power cable leaving the user only one cable to run to the drive thereby simplifying the setup process.
Data available to users
However, users may be curious what data is available to capture from their Hiperface DSL. The following link will guide you to the SICK Hiperface DSL catalog detailing all the specifications, features, and parameters of the device.
Hiperface DSL Specifications
The catalog offers a list of parameters available to the user and their register index to request the data values. The parameter list is summarized in the table below.
Resources index Function Size
(byte, max. offset)
Designation
000h Root node – ROOT
001h Identifier node – IDENT
002h Monitoring node – MONITOR
003h Administration node – ADMIN
004h Counter node – COUNTER
005h Data storage node – DATA
006h Sensor hub node – SENSHUB
080h Type of encoder 2 ENCTYPE
081h Resolution 4 RESOLUTN
082h Range 4 RANGE
083h Type code description 18 TYPECODE
084h Serial number 10 SERIALNO
085h No. of firmware version 20 FWREVNO
086h Firmware date 8 FWDATE
087h Size of EEPROM 2 EESIZE
0C0h Temperature range 4 TEMPRNG
0C1h Temperature 2 TEMPRTUR
0C2h LED current range 4 LEDRANGE
0C3h LED current 2 LEDCURR
0C4h Supply voltage range 4 SUPRANGE
0C5h Supply voltage 2 SUPVOLT
0C6h Speed range 2 SPEEDRNG
0C7h Rotational Speed 2 SPEED
0C8h Service life 8 LIFETIME
0CCh Error log 8 ERRORLOG
0CDh Usage histogram 4 HISTOGRM
100h Reset 0 RESET
101h Set position 8 SETPOS
104h Set access level 8 SETACCCES
105h Change access key 8 CHNGEKEY
107h Limits for warnings 8 UWARNING
108h Factory reset 8 FACRESET
109h User–defined encoder index 2 ENCIDENT
10Ah Position filter setting 4 POSFILT
120h Read counter 4 READCNT
121h Increment counter; life time: 300,000 counting steps 0 INCCOUNT
122h Reset counter 0 RESETCNT
130h Load file 8 LOADFILE
131h Access file File size RWFILE
132h File status 4 FILESTAT
133h Create/delete/change file 8 MAKEFILE
134h Directory 8 DIR
200h I/O access 4 ACCESSIO
201h Manage I/O 4 MANAGEI0
Typically, thermal protection data is provided though a dedicated pin (either in the power or feedback cable depending on motor design). The user must then properly connect this wire to the drive to receive motor thermal information. Note, however, that the Hiperface DSL processes the signal from the PTC for the user and sends it through the two-wire feedback connection via a dedicated register (0C1h). This is thanks to the fact that Parker has selected a feedback model that includes a connection for the PTC which further simplifies the setup process.
See the manufacturer’s specification document referenced above for more information including access levels and error codes and other mechanical and electrical data.
  • MPP
  • Hiperface DSL
  • feedback
  • SICK
