Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base IPA Software - Example - Interact Xpress HMI
    • IPA Drive/Controller-
      • IPA Hardware - DC Power
Note: Position based move is triggered based on a bit sent over and monitored in Prog0, so Prog0 must be running for homing or distance move to work.
Similar to ACR-View's Common Status Panel, the StatusPanel gives status of the IPA.
Note: Drive Reset is triggered based on a bit sent over and monitored in Prog0, so Prog0 must be running.
For ACR-View project and Xpress project, click here to download:  IPA_Xpress.zip
2/14/18jh
