Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base ACRView IEC Editor not Compatible with Win10
      • 9000 (Legacy)+
      • IEC PLC (9600) (Legacy)-
        • PLCOpen State Machine
        • Using arrays in IEC PLC
ACR-View 6.4.2 now available for Windows10 PC's.
The IEC editor not available for Win10. For the few users for existing applications using IEC programming, Windows7 is compatible with the IEC editor with 6.4.2
Note many applications used the 9600 hardware but used only AcroBasic programs. In that case, Win10 can be used with 6.4.2 to edit the projects.
For new applications, the PAC controller is much more powerful and full featured with Win10 support and many more options. Please contact your local Automation Technology Center distributor to discuss upgrading or the factory.
In Win10, new projects have the 9600 greyed out. Existing 9600 projects will warn users the OS isn't compatible:
2/2018jh
