Search
Sign in
Aerospace
Climate Control
Electromechanical Group
Filtration
Fluid and Gas Handling
Hydraulics
IoT
Pneumatics
Process Control
Sealing and Shielding
Blogs
Forums
Knowledge Bases
Aerospace
Climate Control
Filtration
Hydraulics
IoT
Pneumatics
Process Control
Blogs
Forums
Knowledge Bases
Search
User
Site
Search
User
Home
110 WD0 Motor Specifications
More
Cancel
Members
Sub Groups
More
Cancel
New
Virtual Engineer
AC/DC Industrial Drives
Gearheads
Servo Motors
Step Motors
Linear and Rotary Positioners
IForce Linear Servo Motors & Positioners
When should I used a linear motor stage?
What are the main precision application types for linear motor stages?
Can Parker provide custom linear motor stage solutions?
310 Coil Bar Side Mounting Locations
Air Cooling and Liquid Cooling Notes
Can I use the motor in vertical applications?
Current Derate for less <0.5pitch moves
D Dual parallel winding specs
Different types of linear motors
Do the magnets lose their magnetism with time?
Does the motor coil float between the magnets?
Hall-Effect, Home and Limit Module Wiring
High Pot Option
How do I select a linear motor?
How to Wire MHED Limit/Home/Halls Module
IForce Coil Compatibility in Vacuum Environments
Importance of mechanical alignment
Inspection Report
LEM Feedback Troubleshooting & Replacements
LME vs PLME Linear Magnetic Encoders
ML18 Track Weights
Motors used underwater or in the presence of oils
No motors listed in WinTips motor database?
Old IForce actuator part numbering
Omega 44004 Thermistor Info
Parker MotionSizer - Temperature Rise Calculation
Phasing Diagram
Renishaw Optical Encoders
Trilogy Electrical Pitches
Trilogy Extension Cables
Trilogy High Flex Cable Specifications
Trilogy IForce Cooling Options
Trilogy IForce Custom High Vacuum Options
Trilogy Motor Summary & Drive Compatibility
Trilogy Motors with Non-Parker Servo Drives
What are the minimum bend radii of Trilogy THF flex cables?
What voltage for IForce hall-effect sensors?
Which MHED is used within the positioners?
Why do some motors have steel laminations?
Why lamination designs skew or angle their magnets
Winding Tolerances and Resistance Measurement
MX80
mSR
Ripped Series Linear Motors & Positioners
LXR
mPR
XE
XR
ZP Wedge
P8S Position Sensor order codes
How can I know if a given actuator is suitable for use in a specific environment?
Manufacturer Grease Standardization
I need speed and accuracy over a long length. What type of actuator should I use?
What type of encoder options are available for the Trilogy Series?
What type of material is used for the base of the Trilogy Linear Motor Positioners?
LBB / LBZ / LBN Linear Actuator Model Numbers
Parker Limit and Home Sensor Compatibility
Electric Cylinders
T-Slot Aluminum Framing
C3 + Xpress + ETH
Legacy (Discontinued)
Other
Share
More
Cancel
Home
Aerospace
Supplier Resource Center
Climate Control
Electromechanical – Mobile
Filtration
Hydraulics
IoT
Mobile IoT
Pneumatics
Pneumatic Industrial
Pneumatics Mobile
Process Control
Community Blogs
Community Forums
Community Knowledge Bases
The Trilogy catalog 110 electrical specifications are for the more common delta-wound coils (WD1, WD2, WD3 and WD4).
The WD0 is a wye-wound coil and the specifications are here:
110 WD0 Specs
Share
History
More
Cancel
Sign in to reply
