Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Cables - Drawings for Flying-Lead PS cables
For those customers who need to wire a Parker servo motor to a third-party drive, we offer flying-lead versions of our feedback cables. For PS-connector motors, we have a normal version [F-9F1-XX] and a Hi-Flex version [FH-9F1-XX] (XX is the cable length in feet).
These flying-lead cables have the PS feedback connector on the motor end, and a blunt cut on the other end, exposing the 18 wires inside. Although functionally identical (aside from hi-flex capabilities), these two cables have different wire colors.
You may download drawings of these cables below:
F-9F1
FH-9F1
Please note that BE 16 frame motors do not have the temperature switch implemented into the motor due to the smaller frame size.
When configuring an amplifier for a BE 16 frame motor, be sure to disable the thermal switch checking.
If using an Aries Drive with Aries Support Tool, this is the default setting for the configuration wizard. The command to double-check this is DTHERM. To disable thermal checking is DTHERM1.
If using a Gemini Drive with Motion Planner, this is the default setting for the configuration wizard. The command to double-check this is DTHERM. To disable thermal checking is DTHERM1.
