Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base General - EME (Europe) motors crossover to EMN (North America) motors
The European division (EME) of the Electromechanical group offers various motors not commonly found in the North American division (EMN). The EMN team can cross over many of the EME motor to other models readily available in the EMN markets. Below is a cross reference table showing which EMN motors would be the basis for a cross over from a given EME motor.
EME motor
EMN motor cross over
NX
MPP
ACM
MPP
MB, MH, ME
MPP
NK
K
NV
SM, BE, P, or MPP
Other EME motors that cannot be crossed over to EMN motors include the following:
  • EX/EY
  • RS/RX
  • SKW
  • MGV/HKW
  • AXEM
  • TMW/TMA
  • TK
  • ACT
For more information on EME motors, please reference their division site at www.parker.com/eme.
