Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Can Parker provide custom linear motor stage solutions?
      • High Pot Option
      • Inspection Report
      • ML18 Track Weights
      • Omega 44004 Thermistor Info
      • Phasing Diagram
      • Renishaw Optical Encoders
      • Trilogy Electrical Pitches
      • Trilogy Extension Cables
    • MX80+
    • mSR+
    • LXR+
    • mPR+
    • XE+
    • XR+
    • ZP Wedge+
Yes - Parker's engineering team will work with a customer from start to finish developing the exact stage needed for the application.  While a standard solution will work for many applications, some require a modified or completely custom solution.  Parker can provide a custom solution for linear motor stages with features including:
  • Stability sub 100nm
  • Move and Settling Times in under 100msec
  • Repeatability under 500nm
  • Sub 20 arc-sec Abbe Errors (Roll, Pitch, Yaw)
  • +/- 3 microns Straightness & Flatness
  • Constant Velocity to meet application needs
  • Resolution down to 50nm
Types of Custom Stage Solutions
  • Single Axis
  • XY Stages (including Monolithic and open-framed)
  • XYZ Cartesian and Gantries
  • Single or Multi-axis with rotation
  • Large footprint & Long Travel Systems
  • Granite or steel base machines
  • Contact us about your design!
Custom Product Design Options
  • Custom Carriages – size, multiple on one stage, etc.
  • Base material (alloy vs. stainless) and size
  • Special coatings (ex. electroless nickel plated or black anodized)
  • Special connectors and cable management
  • Custom mounting holes
  • Linear brake (for vertical applications)
Custom Solutions for Special Environmental Options
  • Cleanroom Compatible
  • Vacuum Compatible
  • High Humidity
  • Extreme Temperatures
  • Radiation Exposure
  • Certain IP Ratings with the use of Sealing
  • linear motor
  • linear motor stage
  • lxr
  • Trilogy Series
  • msr80
  • msr100
