Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base General - Thermal switch specifications
Motors of any type take some input power (whether electrical, chemical, or some other form) to generate mechanical power. This mechanical power conversion process generates heat as a byproduct, and the collection of this heat is often referred to as thermal build up. Without proper controls or monitoring, thermal build up can reach a level that damages the motor. Thermal switches and thermistors allow automated systems to sense the temperature levels within a motor.
Below are references to the thermal sensors used in each of our servo motors and links to their datasheets.
MPP
Applicable sizes
All MPP motors
Vendor and part number
Thermik – SNM140.ES
Link to datasheet
Datasheet
BE
Applicable sizes
BE16, BE23, BE34 PS connectors only
Thermik – SNM125.ES
Link to datasheet
Datasheet
Applicable sizes
BE23, BE34 without PS connectors
Cantherm F20A110
Link to datasheet
Datasheet
SM
Applicable sizes
SM16 without PS connectors
Cantherm F20A090
Link to datasheet
Datasheet
Applicable sizes
SM16, SM23 PS connectors only
Thermik – SNM125.ES
Link to datasheet
Datasheet
Applicable sizes
SM23 without PS connectors
Cantherm F20A110
Link to datasheet
Datasheet
