Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Compax3 Accessories - MDR Motor Choke Specification Sheets
Attached are the vendor specification sheets for the Compax3 motor filter accessories.
MDR01/01
MDR01/02
MDR01/04
Note - the EMDE division in Europe has adopted a newer part number scheme for some of these accessories, so here is a cross-reference for the models affected.
MDR01/04   is now known as part number ECM-0004-01
MDR01/01   is now known as part number ECM-0001-01
MDR01/02   is now known as part number ECM-0002-01
glh 5/2018
updated glh 7/2019
updated glh 2/2021 to fix downloadable links
  • MOTOR CHOKE
  • MOTOR FILTER
  • MDR01/02
  • MDR01/01
  • MDR01/04
