Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Compax3 Hardware - BRM Braking Resistor Specifications
BRM04/01   (Festwid.15R/0,57KW RFXT3  HEINE)
BRM04/02  (Festwid.15R/0,74KW RFXT4  HEINE)
BRM04/03  (Festwid.15R/1,5KW RFXT8 HEINE)
BRM05/01 (56R/180W EFm3 HEINE)
BRM05/02 (Festwid.56R/0,57KW RFXT3  HEINE)
BRM06/02 (Festwid.33R/0,57KW RFXT3 HEINE)
BRM08/01 (HEINE_GW240 100R 10%)
BRM09/01 (22R/0,57KW RFXT3 HEINE)
BRM10/01 (47R/0,57KW RFXT3 HEINE)
BRM10/02 (47R/1,5KW RFXT8 HEINE)
BRM11/01 (27 Ohm 3,5KW, Frizlen GmbH FGFG31007 02-27 NR.13720)
BRM12/01 (18 Ohm 4,5KW, Frizlen GmbH FGFG31009 02-18/4,5 15023)
BRM13/01 (30R, 500W 10% IP54 TS cable.=30cm HEINE  GWH 337)
BRM14/01 (15R, 500W 10% IP54 TS cable.=30cm HEINE  GWH 337)
Braking Resistor Recommendations for Compax3 Drives
Note - the EMDE division in Europe has adopted a newer part number scheme for some of these accessories, so here is a cross-reference for the models affected.
BRM13/01   is now known as part number ACB-0001-01
BRM14/01   is now known as part number ACB-0002-01
BRM04/01   is now known as part number ACB-0003-01
glh   5/2018
updated glh 7/2019
  • BRM11/01
  • BRM10/01
  • BRM08/01
  • Regen
  • BRM10/02
  • BRM12/01
  • BRM04/03
  • BRM05/01
  • BRM09/01
  • BRM06/02
  • BRM04/01
  • BRM04/02
  • BRM05/02
