Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base What ports get used with PAC Ethernet connections?
The following ports may be used with the PAC (Parker Automation Controller) Ethernet connections:
Function Connection Type Port(s)
PAC Configuration Tool
HTTP 81
PAM Connections
UDP 1740 - 1743
TCP/IP 1217
Network Variable Lists
UDP 1202
Web Visualization
HTTP 8080
Embedded Xpress
HTTP 80
FTP Server 21
Flash Socket 1235
Flash Policy Server 843
Modbus TCP
TCP/IP 502
Note - some of these are simply the defaults and may be changeable by the programmer.
glh   5/2018
  • ports
  • router
  • Network
  • Firewall
  • anti-virus
