Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Compax3 Accessories - NFI Line Filter Specification Sheets
Vendor specifications sheets for the Compax3 line filter accessories can be found below.
NFI01/01 (12FC10)
NFI01/02 (16FCD10)
NFI01/03 (25FCD10)
NFI02/01 (FS8019-84-34)
NFI02/02 (FS5087-130-35)
NFI02/03 (FS5087-220-40)
NFI03/01 (30BCF10)
NFI03/02 (FMAC-0F60-3601 L)
NOTE: Electromechanical and Drives Division Europe has adopted a newer part number scheme for some of these accessories. A cross-reference for the models affected is given below.
NFI03/01 is now known as part number ECP-0003-01
NFI03/02 is now known as part number ECP-0003-02
NFI03/03 is now known as part number ECP-0003-03
glh 5/2018
updated glh 7/2019
20MAY2020 DCLIFFE - Corrected data sheets.
  • NFI02/02
  • NFI02/01
  • NFI01/03
  • NFI03/02
  • mains filter
  • NFI01/01
  • NFI03/01
  • NFI02/03
  • NFI01/02
